vcSimulation
Object type for simulation engine, thereby providing access to the scene graph and simulation controls.
Referenced by: vcCore.getSimulation()
IsLoopingBooleanRWGets or sets if the simulation gets automatically restarted when finished.
IsRunningBooleanRGets a value indicating if simulation is running in 3D world.
RealTimeModeBooleanRWGets or sets if a simulation runs in real time or virtual time.
A True value means the simulation runs at a speed indicative of the real world environment. A False value means the simulations runs at speed based on the device's CPU processing speed.
SimSpeedRealRWGets or sets the step size or speed of simulation.
SimTimeRealRGets the current simulation time in seconds.
SimWarmupTimeRealRWGets or sets a time in seconds of simulation warmup time.
SimulationRunTimeRealRWGets or sets a time in seconds when simulation should stop running.
Note: Changing the SimulationRunTime is only allowed in the OnRun event.
autoHaltBooleanNoneStops a simulation if there is no active component running a script that generates simulation events.
bool: Status of the halt operation. True on success, otherwise False.
haltNoneNoneStops a simulation immediately.
resetNoneNoneResets simulation and static components to initial state and sets simulation clock at zero.
restoreInitialStateNoneNoneRestores simulation and static components to initial state.
setFastSchedulingNoneBoolean enabledUpdates the fast scheduling flag for all conveyors that support the property.
enabled (bool): Value to set.
setInitialStateNoneNoneSaves the current state of simulation and static components.
RuntimeError: When no license for Simulation Settings API.
startNoneOptional Keyword[runtime = Real]Starts simulation to run for the specified duration.
Optional: runtime (float): Simulation runtime in seconds. If not provided, simulation runs indefinitely.
updateNoneNoneUpdates simulation and 3D world to reflect current state of components.
NameParametersDescription
OnStateChangedvcSimulation simulation,
vcSimulationState state
Triggered when simulation state was changed.
Note: when simulation is reset, it will trigger this event 2 times,
first with vcSimulationState.STOP and then vcSimulationState.RESET.
simulation (vcSimulation): Simulation object instance that was reset.
state (vcSimulationState): State of the simulation.
